35 Johnson stuck in fwd gear
rocketjacket
I was making an adjustment to the gear selector cable & i moved the controler arm (gear selector) & it went a little loose. Now i only have forward gear, does anybody know how i can fix it?<br /><br />Thanks...
Joe Reeves
Re: 35 Johnson stuck in fwd gear
Rocket..... It would appear that you may have pulled the shift linkage apart. However, the linkages differ through the years. What is the model number of your engine?
