351 FORD COBRA omc 1997 injected
RGORE
I recently bought a cris craft 34 ft that was not running, we found that distributor needed to be replaced it was rusted. The motor starts but runs rough and only on four cylinder, when you pull the spark plug boots the spark is hot and snaps, you can hear the injector as well. It seem to run on 2-3-6-7 and seems not to run on 1548. I though that it might be an esa module but know were it is or how to check. The boat is in the water thanks for you help Richard
clanton
Re: 351 FORD COBRA omc 1997 injected
No service manual. The 93 model fired the injectors in sets of 4. Check the fuel pressure and voltage to the injectors. Compression test, if the dist was rusted what do the rings and valves look like?
RGORE
thanks<br /><br />the compreshion is good, how would you check the voltage to the injector, and fuel pressure thanks richard
