Captcheetah
- Joined
- Aug 21, 2002
- 45
Found a used '91 MasterCraft Tri-Star (un-seen)with a cracked block, 351. I just happen to have a balanced and blueprinted 302 that I built for my Mustang in the garage. What type of problems am I looking at by trying to put the 302 in? <br /><br />Distributor <br />Exhaust<br /><br />Are aluminum heads an issue on a boat? What kind of compression is excessive for a boat motor? The motor is set-up for around 390-400 crank HP @ 5600 rpm/10 to 1 compression. I would likely trade out cams to get the power down in the 4k-5k territory and maybe knock down the compression.<br /><br />Oh, believe it or not, fuel consumption is an issue.
