Hi , took my 35hp '83 Evinrude / 18 ft Shetland out on the cold UK sea today and yesterday and gave it some WOT and it went very well. Both times on restarting to get it on the trailer it was very rough on idle and wouldn't rev as it does normally, at higher RPMs it was fine. When I got back i pulled the plugs and the lower one was wet, with water I think (kind of a milky coffee coloured look).. I cleaned them and ran it in the dustbin and it went much better. If I run it solely in the bucket (ie at lower speed) it is always fine so it looks like it is a problem caused by running at higher speeds.
Having searched the forum the following could be the problem..
1. Water in from the Exhaust gasket / plate.
2. Water in from the Head Gasket
3. Maybe something to do with reed valves somewhere? (a thread I didn't quite understand)
4. Water coming in through the carb, from being splashed in (unlikely i think as the cowling prevents it) although a badly placed ladder does splash some when its on the plane....
My question is, is this a reasonable set of reasons and are there more?
thanks in anticipation
David
David
