Re: 35hp evinrude 1978 35803r a335093
thank you very much for the info.I believe i nee the shift assembly that goes into the the motor cover.the part is a steel flat bar with two indentations for fwd.@rev. gears. can you supply a breakdown of the right side inner housing. thankyou very much.<br />i see you live in corpus christi tx.I lived there for about a year.in was in the late 70s. i worked at the cement plant .centex cement it was called then. i believe it is no longer going.I spent a lot of time going to padre island. great place.<br />so long for now fudge.(dogs name)
