I haved a 1979 35hp rude that seems to be running on 1 cylinder. 2 weeks ago I had the carb rebuilt and it seemed to run fine on the muffs. Once in the water it would only run on 1 cylinder, sputter a bit then the second cylinder would fire. It would run like this for a bit and then back to 1 cylinder. I changed the plugs and again at home on the muffs both cylinders fired without missing a beat. Once I got it in the water, same problem as before, only 1 cylinder would fire. When I pull the plugs the bottom plug looks great but the top plug is always wet with a oily looking substance. Any advice would be greatly appreciated.
