SouthCarolina1
- Joined
- Jun 17, 2013
- 169
I just bought a 1979 35HP Evinrude Model 35953A. Motor looks rough but it has good compression. Anyways the seller pulled it off his rotting boat and decided the easiest way to remove it would be to just cut the wire harness at the motor... I traced the wire harness back to a plug. The wires going into the plug from the motor are in bad condition and somebody in the past has made several repairs to the wires. Instead of buying a wire harness I am just going to make one by wiring the switch terminals directly to the individual components. The existing wire harness has five wires and I need help determining what is what and where to land the wires on the starter switch. Looking at parts and found that the Sierra MP39760 starter switch will do the job. Check out my pictures I labeled the wires on the plug 1-5 and included a diagram of the switch terminals, all pictures have comments for them. I need to know where to land these 5 wires on the switch terminals M, B, M, C, I, and S. The switch has six terminals, I think one goes directly to the battery which is why there were only 5 in the wire harness? Any help is welcomed.
