1982 Johnson 35hp model J35RCND manual start.<br />Engine idles rough when running in a barrel. So far I have changed water pump, removed carb and cleaned, replaced thermostat,checked and set sync and link,new sparkplugs. When running fuel bulb is hard (new tank, bulb and line).Compression is<br />100 lbs top cyl. and 95 bottom cyl.<br />When running at idle, if I pull the top plug wire, there is no change. If I pull the bottom wire,engine stalls. If I increase slightly above idle speed and repeat this it will run on either<br />cylinder. Seems to me the top cylinder is weaker for some reason. I replaced the coil on that cylinder, but no change. Could this be a bad powerpack?
