35hp johnson problem
jhawk
having problems with motor starting in idle position, especially when motor is hot. Also can not keep motor running at idle. can anyone please help me!!!!!!!
sloopy
Re: 35hp johnson problem
sounds like a clasic carb prop! clean them out and decarbon the engine!
alcan
Hi Jhawk<br />Could you post the model# of this unit. From your description it sounds like you may need to make a few adjustments. It also sounds like you may not be using proper starting procedures. Try to tell us a little more about your rig. Manual start,tiller or remote control,Etc.
