racerdonnie13
- Joined
- Sep 15, 2008
- 24
I have a 1965mercury 35hp (merc 350) it was working fine last year when i parked it. I pulled it out yesterday and it fired right up but would not go into either gear. everything looked good up top so i pulled the gearcase. The shift shaft that goes down into the lower unit seems stuck, i cant turn it by hand. I put an inverted torx on it with some pb blaster and got it to turn Somewhat in both directions. How far should it turn, and should i be able to turn it by hand? As i turned it i was able to get all 3 gears (by turning the prop). Thanks for the help
