DevinM
- Joined
- Jun 16, 2020
- 28
35EL78R
So this isn’t running right. When I have it running for a few minutes it seeps unburned 2 stroke oil out of the wheeling hole of LU. Found a weak spark on #1, the clean cylinder, replaced power pack and got strong spark. Have 110psi when it’s cold. Wanted to replace some gaskets today and was surprised by what I seen.
Even after PP replaced it coughs/sneezes at idle. Idle needle is fine and have it backed out 1 1/4 turn. Going for gaskets behind the reed valves because I had a peddle fall off and replaced it w/o gasket with no issues for months after. Good thing it exited through the exhaust lol
I don’t have a boat to put it on to test timing after PP installed as the book says to check.
I’m just wondering if I got water #1 why didn’t it clean the spark plug too? Am I about to burn #2 cylinder? If anything it looks like water could’ve got in #2 because there are beads of water around the diameter. Something seems very off balance. Please let me know what you think. Appreciate you guys. Be easy on me.
