Re: 3m 5200 arg
the above 2 posts are very correct.
5200 is like sillycone.....it comes out of the tube the same way.
and my good friend smoke. is also correct.....unless you really pierce the seal of the tube,,,,,you are tring to force the goop thru a pin hole.
the deal is.....that 5200 is a very specific use product.......so it can sit on the shelf for a while....
i have run into many store bought tubes that were just out dated.....
make sure that you have a good hole in the tube to squirt thru....then apply the nozzle
if its still hard.....take the tube back and tell them to replace it.
thanks for all the help guys,
first of all i had to stop at 5 stores to find the stuff and all that was avail was the 1 large tube.
before using i removed the cone and used a screwdriver to clear all of the (al u meeenum type
) end cap
nope it was not runny by any means infact had the consistency of cement
. i ended up using the ground to help me push enough out and applied with a
gloved finger. that stuff still sticks to anything, lol. got the job done but was a pita
i bet it would stick to a moss covered rock in a stream bed,,,lol
last question when i bought it i assumed it had a born on date of 10/08 i know better now,
who knows mayby the'll take it back and trade for a new prop:facepalm:
lol that stuff is cheap lol
since its water cured i guess i should wet it down then,,, huh
thanks again guys
