3M sealer
matty133
hey guys,<br /> What 3M product should i use for my through hull fittings below the water line such as the blige hole. (im not sure if thats what it is called) Also what should I use to seal the top of the boat to the bottom? 3m 5200? Lastly what are good options for foam. The pourable (EXPENSIVE) stuff? Or would home depot insulation work? Thanks <br />Matt
imported_bjs
Re: 3M sealer
i use a 3m sealer its the best for below water line i cant remember the # i ve ued the 5200 before that what i would use. im not sure about the foam i know the foam they have at hardware stores does not dry to a hard finish i dont think i would use that foam.
