4.3 1996 flywheel teeth?
Ayuh,..... If the starter is a straight across bolt pattern, it's the 12" wheel, 153 teeth,....
If the starter is the staggered bolt pattern, it's the 14" flywheel with 168 teeth,....
philbullet
I need to pull and replace gear ring and want to pick one up local at auto parts dealer.
I in a time crunch, is it possible to find a auto replacement?
philbullet
Yah it is staggered , small geared down starter
Your flywheel and ring gear don't know if they are installed in a marine motor or truck motor. Its the EXACT same part.
philbullet
Thanks, it was off of a marine motor, only thing that I have that wasn't on marine. Is the long block but cam is 260 from marine eng.
I found a ring gear from auto zone and got it all changed out today.
It got it messed up from cracked exhaust matifold and was getting water in cylinder / hydro locking.
Kept cranking on it trying to find my 10 problems I had.lol
I also had water in gas ,carburetor , oil, etc.
When it rains it poors.
Keep dishing out the cash is the name of the game.
This problem s all started after I let my cousin borrow my boat to go catch him some shrimp.
He some how ram out gas, almost sunk it which is how I got the water in gas tank.
Bluh bluh.
