4.3 4b 9600s 1995 vintage
SHELBY3
got new motor in boat , rebuilding carb used a edelbrock kit and used a 1485 tunning kit, my question is can i add a electric chock to this carb? i changed to vortec heads and got new intake, mercruiser, the old intake had chock stove in intake that operated chock. or go with no chock, thanks ahead of time this is one of the best forums ive ever ran into. mac
Re: 4.3 4b 9600s 1995 vintage
Ayuh,...
Wander over to the Edlebrock site,+ see if they offer an Electric converstion...
If they Do,... Buy it....
The Edlebrocks,+ the Merc/ Weber is the exact Same carb....
I've been using Edlebrock parts on mine for Years,..
Shelbyb117
my experiance is with autos not boats but two ways of doing this,, first the carter carb set up for a carb mount'd choke has a diff top then the one you have,, you can how ever use a intake mount'd choke from a late 60's to early 70 chyr product that had a carter carb , that electric choke came with a sensor to activate it so all you need is a key'd power fed to it , the sensor bolt'd on to the choke mounting bolt and was wire'd to the heating eliment.
the arm can be fab'd to what ever length you need
now finding an older carb'd car can be a problem, most have been crush'd . but if you can't find any thing i may still have one in my tool box , i'l take a look see , if i do it's yours
