4.3 Carb vs 5.7 Carb
Lukey220
Hey everyone, I successfully swapped the 5.7 into my boat and only thing left is the carb… I cant find any specs on the carb I have only possibly due to its age. Curious on if the carbs would be similar between a 1981 Merc. 5.7 and 1988 merc. 4.3 other than the 4.3 being 2 barrel and 5.7 being 4 barrel. I don’t really know much at all about large carbs so any help would be appreciated. Would the 4.3 carb work or should I start looking for a 5.7 carb?
Thanks!
Scott06
Hey everyone, I successfully swapped the 5.7 into my boat and only thing left is the carb… I cant find any specs on the carb I have only possibly due to its age. Curious on if the carbs would be similar between a 5.7 and 4.3 other than the 4.3 being 2 barrel and 5.7 being 4 barrel. Would the 4.3 carb work or should I start looking for a 5.7 carb?
Thanks!
In a word no they are not the same carbs. Even if they were both 2 bbl carbs they would have different jetting and possibly the venturi cluster is different.
I went through the same exercise when I did a 4.3=>5.0 swap and got a Edlebrock 1409 and it works great, would recommend you do the same, should work pretty well on a 5.7 right out of the box
Lukey220
I
Awesome, thanks for the quick reply. Will start shopping around.
Lou C
Even if the carbs were identical; if they came from different displacement engines the jetting, metering rods; and various other parts will be different to allow for the greater volume of air flowed by a larger displacement engine.
Scott06
Summit Racing has them (1409) in stock.
Mecruiser part number 805359T throttle bracket will work with the 1409 as the 2 bbl carb bracket will not. Makes a nice clean install of throttle bracket
Lukey220
Will I need to get an adapter plate if I go that route due to my intake being a spreadbore and edelbrock being squarebore?
