docoakley01
- Joined
- May 24, 2009
- 11
Hello. Trying to get a used boat I bought last fall seaworthy. I had a clicking from the slave solenoid on a 4.3 99 Crownline with a Carb. When key was in the on position, it would also make a low warning tone. Ran a bunch of checks and then found the battery would just not hold a load. Replaced battery with a proper marine unit, and started. Tone was gone, and unit fired right up. Did this a few times. Let the boat set for a few hours and I still get the warning tone, but the engine still starts. I am concerned that I might have a draw causing the battery to get a bit low, causing the tone and eventually killing it. The previous owner replaced the cluster. I can't imagine what type of draw might bring down a 1000 cca battery down over a short period of time. I can't find how low a voltage might cause the warning, no spec in the book or am I just barking up the wrong tree? Thanks for any help, this site is great, I am learning alot.
