Old motor: Mercruiser 4.3 with I believe a T-Bolt IV ignition
New Motor: 4.3 rebuild from a '96 S10 (true vortec + balance shaft)
To avoid having to deal with an electric fuel pump since the 96 block has no provision for a mechanical, would the newer balance shaft crank fit the '90 block?
Will the old T-Bolt IV ignition run the vortec motor?
Will the flywheel on the '90 work on the '96 balance wise?
