4.3 electric fuel pump no power. Puzzled…
Group_er
Engine serial # Om346350
No power at fuel pump.
Purple wire on starter stud shows 12v while cranking. As it should…
Oil pressure switch received 12v while key is in run position. As it should. (Currently jumped closed with a paper clip)
Still no power at the factory plug for the fuel pump.
From the research I’ve been able to do, these are the only two things I’ve learned to check. Can anybody direct me in another direction?
Any help very much appreciated!!
Thank you.
achris
More fish than mountain goat
Use a multimeter and check the wire between the pump and the switch, and also check the negative side of the pump supply...
Bt Doctur
testing voltage is fine but where are you testing for the ground side?
