numbered01
- Joined
- May 28, 2012
- 24
Hello, I am having this problem with my 1987 Mercusier 4.3 engine. Engine number B602338. It has the 4 barrel Rochester carb on it. The problem is the engine starts fine and idles good in the beginning. After I drive it for 10 minutes the engine starts to bog like it's starving for fuel or cutting out on me. I will run it at 3000 RPM and it wil drop to 2000 then back to 3000. It gets slower the more I have it running and when at idle speed it runs fine. I cleaned the flame arrestor and still has the problem. Today I am changing the water/fuel seperator and the filter in the carburator. I will see it that is the problem and get back to you. Is there anything else I need to check if that does not cure the problem?
