4.3 GL Spark Plug Gap
jmb23802
Those of you with the 4.3GL in your boat that also do your own maintenance what gap have you set on your spark plugs?
I have an original 4.3GL in my 2003 Four Winns and while checking the gap in the plugs and doing some other spring maintenance I discovered the VP Operator's Manual that I have (version "09-2002") says to gap the plugs at .060 while the VP Workshop Manual (version "03-2004") says to gap the plugs at .045. Both books reference the same part number (3861632) for the spark plugs on the 4.3GL. What gives?
ericga
Go to www.volvopentastore.com
-> Genuine Volvo Penta Engine parts
Select your engine
-> Maintenance parts
You'll find the spark plug part number and gap. That information should be accurate.
jmb23802
Thanks for the info. According to the site referenced above the "red" engines (2001+) appear to require a .060 gap and the predecessor "charcoal" engines called for a .045 gap. Looks like the workshop manual I have, which appears to be a newer edition than the operator's manual, has not been updated with the new gap spec (makes you wonder what else was not updated also).
Wish I had figured that out before I gapped the plugs to .045. Oh well, practice makes perfect :bowl:
