Donald Terrell
- Joined
- Jul 17, 2004
- 69
My boat which usually ran very well has been stored for a couple years.Last month I took it out after changing fluids and installing a new impellar. It ran poorly like it was running on 4 or 5 cylinders but it would occasionally shoot forward and run good only for seconds though. I noticed that the temp guage was not coming up,at first I thought it was broke,however it wasn't. I replaced the thermostat which was broke open. I did inspect the points,cap,button,wires and two plugs which all seemed fine. I thought I had solved my problem with the thermostat and the engine would run fine after reaching operating temp,but I was wrong. Today it ran just as bad.It normally will top at about 44 mph but today never hit 34mph. At full throttle it would surge and slow on its on.On the lake I removed the cannister fuel filter,dumped gas into a clear conatainer(looked clean, no water) and also inspected the small filter at the carb.I removed the gas line from the rear, built in, never seen it before gas tank. No gas flowed out and I couldn't blow air into the tank.I've read about an antisiphon device.All I plan to try next is the flow rate test of the fuel pump. I read on another post that Bombadier discontinued the stern drive division meaning that parts would get harder to obtain.True?? I usually leave longwinded post as this one but I just want to give enough info,apreciate any help!
