Hi All,
Greetings from a very warm Australia.
Apologies if this doubles up bit I lost the initial thread I was typing. I have a 4.3 GXI-B in a Larson 214 escape that is giving me some grief and I have spent a fair bomb on it so far, and am hoping someone has had a similar problem.
It goes into limp mode intermittently, had an intermittent surging problem and now has an injector driver fault (Diagnosed after countless thousands at the local Volvo Penta dealer). I have replaced the thermostat, impellor, both exhaust manifold temp senders, oil pressure switch, knock sensor and coolant temp switch (the one with 2 wires on the thermostat housing), and have drained the fuel tank and refilled it. There was some water in the filter which has also been replaced. The exhaust manifolds have also been off for a visual inspection and the gaskets were replaced also. So it's now parked up over Christmas which was not the result I was looking for. 2 weeks ago the boat ran fine for over an hour at near full throttle, yet last week it went into limp mode after about 30 minutes, played up about 20 times then would not even start. I found myself at the wrong end of a coast guard rope....good thing I was a member and am still paid up. The VP dealer has tried a new ECU but the problems still persisted. The alternator is charging at around 13.5 volts and the batteries are new. No shorts to ground at pin 20 of the J2 connector, and tried moving the harness / checking for secure terminals etc
I measured the voltage at the oil pressure switch today just trying to eliminate things and it has about 4.7 volts when hot.
Is this ringing bells with anyone? I really appreciate any help or feedback.
Regards, Allan
Regards, Allan
