My 91' bayliner has an engine with a cracked block (bought it that way). I've pretty much decided that I will use an automotive engine as the base for the replacement. I plan to replace the cam with a marine cam and I'll put brass freeze plugs in it. I also know that I will need an electric fuel pump if I go with a 92' or later engine. The current cam and crank are damaged from being run with water in the oil so there's not much left worth working with. <br /><br />My question is what years of engine can I get away with using most of my externals including exhaust?<br /><br />I know that I will need a different intake manifold if I go with the vortec's.<br /><br />I'm looking at a 2003 engine with 20K miles on it. Will my current exhaust bolt up? Can I use my distributor? I'll probably run the current 2bbl carb so I know I'd need an appropriate manifold. What about the accessories? This engine is stripped of all externals. Can I use the old brackets and accessories if I change the crank pulley to a V-belt? <br /><br />I know these engines changed quite a bit around 2002-2004 but I'm not very sure about the specifics.<br /><br />Thanks for any help.
