4.3 L oil sending unit location on engine
timjet
I just had my engine replaced with a rebuilt 4.3 L mercruiser engine. The mechanic failed to connect the oil sending warning unit. I think he just forgot to connect it electrically. I get no buzzer with the key on indicating low oil pressure. Can someone guide me to it's location on the engine?
Fun Times
Hi there, what year engine do you have? Engine serial number handy?
ONEGA
Both units should be located on a tee fitting at the rear on the port side of the block by the oil filter.
Ayuh,... Way down Low,.....Just above where the block turns into the oil pan,...
Volphin
Yep, and if it's an older 4.3L, it will be attached with a T right behind the intake manifold, next to the distributor.
achris
More fish than mountain goat
Two conflicting positions. That's why we ask for an engine serial number. OP, do you have that yet?
