This may be a stupid question, so please forgive my ignorance. I recently bought a 1988 20' Sunbird Cuddy Cabin with a 4.3L OMC Cobra. The first time I took it out on the water, the upper unit of the outdrive failed and I suspect that there may be problems with the lower unit. When I ran the engine on the hose at my house, I had trouble shifting into reverse (a grinding noise and the whole boat shook). The engine runs great and I was wondering if you can mate an OMC Engine with a Mercruiser outdrive? Also, could the trouble shifting into reverse be caused by the upper unit, the lower unit or both? Thanks in advance.
