catcatcher
- Joined
- Dec 9, 2007
- 33
After blowing a hole in the #6 piston and endeing up replacing 2 piston and 4 valves on a remanufactured motor with around 15 hours on it. I got the motor back in the boat, aligned it, and finished the install of all the engine components. I pumped the 15 gallons of old fuel out and put 10 fresh gallons in to start it and see how it went. After getting the timing set it starts and idled good. So, the next step was to drop the boat in the water and see how it did under a load. Today was the day for that and it went well on the inital take off. The motor came alive but I could only reach 3900 RPM's. I ran up the lake a ways and turned aound which is when the problem started.
Half way through the turn the RPM's dropped below 3000 and slowly climbed back up to 3500 where it stayed for the remainder of the run. When I pulled the throttle back and came off of plane the motor began spitting and sputtering. So, I throtled back up and it took a minute to clear up but once it did again I was only getting 3500 RPM at WOT. When I brought it back to an idle it spit again and died. It started right back up but was ideling much higher than normal. It was turning 1500RPM at idel now so I lifted the motor cover and pulled the throtle linkage forward and it dropped back to 700RPM at idle. When putting it on the trailer it died as the bow was meeting the rollers but, once again started right back up at a high idle.
Could this be caused by a weak fuel pump? My dad rebuilt the carb and I am wondering how well of a job he did so maybe this could be it?
Any other opinions to the problem are greatly appreciated!
