My boat has 250 hours on it, and I am having some issues with it this year. I only put about 20-30 hours a year on the boat because we are usually so busy with my son's tournament baseball over the summer. Anyways, the boat cut out a few times as I was getting it ready this spring with the muffs on but only a few times. I replaced the water/fuel separator but only had a few hours free today to get it into the water and docked at the marina (freshwater). So we did a few runs down the lake and the motor wants to cut out when I put it into gear unless I give it a little more revs then it worked fine. We went up and down the lake with no issues other than it wanting to cut out when I put it into gear at idle.
Then, as we were running about 3/4 WOT, it was hesitating at higher RPMS and I kept backing off the throttle until it died. I let it sit about 5 minutes or so with the blower on and the engine bay open. The boat started up again but I didn't push it and went pretty slow on the way back to the dock.
I realize there are numerous things that could go wrong, but it starts right up without any issues so no spark issues at least initially. I am thinking a fuel issue or dirty carb. I plan to clean the small screen in the fuel input line to the carb, but any other easy things I should try? I probably could rebuild the carb myself, but I may just take it somewhere because I just don't have the time. Would prefer trying whatever I can before pulling it right back out of the water and potentially losing a couple weeks of summer boating.
I did as much snooping around on the web and people say vapor lock in just about every thread, but it has issues cold and warm so I doubt that is an issue. Can I clean the carb enough while the boat is in the water to try to make it to the fall and then have someone rebuild the carb?
Any way to check if it could be a bad tank of gas? I put stabil in when I winterized it in the fall.
