4.3 Mercruiser Car Engine has a stutter when starting
jdelisle
Mercuiser 4.3 engine The engine turns for s second while starting then a quick hesitation then spins and starts up. . I've replaced the the relay and starter and problem still exists.
Is it an electrical issue, timing, Any help appreciated.
Bt Doctur
a slight hydro-locking issue? oil clean? age of manifolds and elbows?
jdelisle
Oil changed in fall is clean and no traces of water. Manifolds and elbows original to 04 boat and run in salt water and flush after each use. However, I have to change or clean thermostat during the season due to scale debris. I'll keep a close eye on oil.Maybe I should pull plugs and try to start to see if anything spits out cylinders?
