bluewater19
- Joined
- Apr 25, 2003
- 505
I have a 2003 17 ft glastron 4.3 mercruiser 190 hp carb motor with a little over 2oo hrs on the stock plugs. I thought I would change out the plugs. After pulling and reading the plugs I found the following readings.<br />cylinder 1 and 2 were somewhat lean(white electrode with a little erosion), and the rest were fine (Light red in color with no erosion). The plugs are the stock AC double platnum.<br />I assume you read the plugs the same as you would on a car right?<br />Is this normal with this carb'd motor?<br />The motor runs great, I get good mileage, 4800 rpm WOT with a 23 pitch high five prop.<br />The boat starts right up every time. I just don't want to burn a valve or hole a piston<br />Thanks
