Steamin Seaman
- Joined
- Nov 24, 2016
- 17
I hope to provide all the information needed for you pro's out there. So i replaced a coil, cap and rotor and an ignition module, because i wasnt getting fire. I made very sure to replace the plug wires in the EXACT same format. i took it out and she ran like a new kitty cat. i took it out of the water, went to a party, came back with family and friends, and she ran great as we proceeded to the party cove. after a while, we decided to cruise the river, thats when it happened. we were cruising about 4k RPM at somewhere between 35-40 MPH. i backed off as i saw some logs and then when i went to throttle again, it only sputtered at 3k and maintained idle speed. i have noticed the therm never read above 140, so i figured it wasnt opening and replaced with a 160 degree thermostat. she ran above the 140 and i thought problem solved. i took it out on the water, same same. idle all day just fine, rev up in neutral just fine, idle speed around the bay all day just fine, but bogs when throttled and stalls around 3k RPM. checked my fuel/water seperator and seems ok. thoughts???? thanks guys.
oh yeah, its an 08' Tahoe Q7i with a 4.3 TKS, carb. no motor serial number, sorry.
