I have a 2003 4.3 mpi alpha gen II- when the engine is cool or within 10 minutes from starting it ......you can shift all you want (forward or reverse) and the engine never stalls. Now run the boat for 10+ minutes and as soon as you put into gear it stalls-you can do the shift into forward with quick gas and it will keep running -its worse going into reverse. Do you think it can still be a shift cable? I removed the cable from the engine transfer-plate and shifted by hand -it was a little stiff but not bad......any help would be great
