4.3 not starting.
edmar
Engine ran great for the first two days went shrimping and started the motor several times,<br />then the starter would not turn the motor over, no strange noises or any sign of strain,replaced the starter and still wont turn engine over.Batteries good,prop turns over in nuetral with no drag,Do I look for engine problems or outdrive problems?<br />Tks,<br />Ed
DJP
Re: 4.3 not starting.
You look for a starter wiring problem. Mabey a battery Isolator problem if you have one, or a weak ground or a poor hot lead. Corrosion, corrosion, corrosion.
