Bansheex13
- Joined
- Jun 18, 2008
- 72
Should I get a high pressure oil pump or just go with a stock replacement? How about a high volume? The motor I am using had a remote oil filter,so I just removed it and installed the threaded fitting from my old motor so the filter would be a direct screw on like before,the question I have there is,the other hole where the oil filter screws on is spring loaded and I never paid attention to other motors becase I have never ran across a remote filter before.Do all motors have that spring loaded check valve for the oil filter? Do I need to do anything other than remove the remote filter cover and install the fitting? I think its alright the way I have it but would feel better hearing from someone who knows for sure.
