Re: 4.3 on an alpha 1
What are u a mechanic or a psychiatrist?
probably some of both... if you ask me... especially for the pigeons that are looking for answers...
4.3 works great with an alpha, I know it's heresy on here, but there isnt any real reason why, especially with a faster, lighter boat, that you can't use your gear ratio and a higher pitch prop... 1.84 to 1.99 is not that tremendous of a difference... as long as you prop for the right rpm of the engine you install. alpha is "rated" at 300 hp...
crate motor needs a fair number of things to make it "marine ready" can find lots of details by searching on here,
the biggest expenses are going to be all the little stuff... marine starter, distributer, ignition, alternator, etc, etc, etc...
and you're right... probably cheaper and easier to buy a bigger boat with a bigblock alread in it... my two cents...
