Merc_man77
- Joined
- Jun 12, 2019
- 21
Hey all, first time boat owner and poster here. I recently bought a 96 sylvan 17 ft with a 4.3 and alpha out drive. On the test drive the speedometer said we reached about 46 at 6000rpm. I read the recommended peak rpm at wot should be around 4800. Is it even possible that engine revs to 6000 rpm or is it more likely the tach is off? The motor did sound to be screaming some as my dad has a 18ft with the same motor and it doesn't sound like it runs as high. If it matters it has a blade prop aluminum pitch, idk the pitch but it is pretty chewed up. Would a 4 blade prop with maybe a 20 be about right? Any suggestions would be appreciated as I'm new to boating and internet research is only getting me so far
