Hey guys, got a new problem as of late with my friends boat. seems to be overheating or at the very least temperature begins to quickly climb when boat is at idle. Anywhere from idle to 2000rpm actually. runs between 140 and 160, lets say 150 for arguments sake, all day until you back off the throttle. within about 2 minutes the temp gauge is up to 180. it may go higher than that if left to it but when he notices it climbing, he gives it throttle and anywhere above 2000rpm the temp quickly drops back to normal operating temp.
He's had this problem before and it led him to replace his manifolds and risers. That was 3 seasons ago, but the boat ended up sitting for a season so there really isn't alot of time on these manifolds. That fixed the problem for him. And once boat was returned to service this year, it worked as it should. within the last 3 weeks the issue started to reoccur. Any ideas? Can't possibly need new manifolds again could it? Thanks in advance guys
93 4.3L with alpha one drive
