4.3 Replacement fuel pump
sdocken
I have a 2007 with the electric high pressure fuel pump. I have contacted a local MerCrusier dealer he said a replacement is $650!
Anyone have a idea of a cheaper solution?
Scott06
They are made by a company called Airtex search the web and yiu will likely find one. Just make sure you get the higher pressure one as they also make the low pressure pumps for carbed engine
sdocken
Thanks for the information, do you know what the fuel pressure is rated at?
If you are MPI, there are two airtex/Carter pumps
