4.3 mercruiser 1998 18.5 bayliner alpha 1
I put a new engine water pump and 160 stat on this past weekend. Reason for this was the weep hole on the pump was leaking. The impeller is around 1 year old.
My driverside riser is getting hot but still be able to keep my hand on it. and my passenger side riser is staying very cool. I am guessing its time for new risers? I put the water hose on the hot riser water inlet and it flowed well is this normal?
I notice that this is a one piece riser and really don't see many of these.
My boat runs at 175 on the muffs with a 160 stat i think this is a bit high. Will it run even hotter under water load?
