13crazyhorse
- Joined
- Apr 4, 2010
- 147
I have a 2002 trophy with a 4.3 mercruiser. Runs great and always did till now. Half way thru the summer I powered it up to get on plane and it overheated. Alarm went off temp 200+. Shut it down and went in on the kicker motor. Replaced the thermostat. Ran it a little still threatened to overheat so I changed the impeller. This made it better it wont overheat when powered up but still runs warmer than it should. Temp gauge reads 185. Correct thermostat installed is 160. One manifold and riser is considerably hotter than the other. I checked it with infrared temp gun and one side is around 125 while the other is 180 and up to 200 if you get close to the engine. Pulled off the manifold and riser and they are both pretty clean. No blockages or major rust. Any ideas on what to do next? Thanks for any input.
