4.3 set timing?
13crazyhorse
I have a 2002 4.3 mercruiser carb in a trophy. Whenever I shut it off it runs on. If I let it idle a few minutes it doesnt do it. There are no timing marks on the front of the engine. How do I adjust the timing and do you think thats the problem? Thanks for any help.
achris
More fish than mountain goat
Sounds normal, unfortunately. With the quality of fuel not being what it used to be, this is the result. The standard reply to people who have a run-on problem is to let the engine cool for a few minutes before turning it off. The alternative is to upgrade to an MPI engine.
Read this thread (click HERE) for the answer to this question.
Chris.......
Lou C
Interesting I have heard this about Merc 4.3s yet never once experienced this on my OMC version with the Quadrajet. I thought Merc had a TSB addressing this issue.
Lou C
I always used at least 89 octane fuel if not higher the gas docks here only sell 93 octane. Even with my old cyl heads I never had run on or pinging.
key off in gear and the motor will kill
13crazyhorse
Ok guys thanks for the input. My marina only has one fuel available. Maybe I'll try some octane booster.
Lou C
Although the Merc service bulletin does not specifically mention it, I would check for drips from the discharge tubes in the venturis after the engine is shut off. Run it as you normally would, shut down and then remove the flame arrestor. Look down the carb throat with a bright LED flashlight and see if you see fuel pooling on top of the throttle plates. Also make sure the throttle plates are compeltely closed when the throttle is pulled all the way back in neutral. If not you might have to adjust the throttle cable.
The only vehicle I ever had that did that was our old 1970 Ford Torino with a 302 V8 and a 2bbl Autolite carb. It had a bad auto choke before we got it, which never opened. I fixed that but the engine had heavy carbon build up due to running rich all the time and it did diesel after shutting it down. I cured it by running GM top engine cleaner through it a few times, literally chunks of carbon came out the exhaust! After that it was much better.
13crazyhorse
Thanks Lou for the reply but it has done it since I've owned the boat (5 years) in which time I've replaced the carb along with tune ups, etc, etc with the same results so I'm beginning to think it's just the nature of this beast and just letting it idle for a couple of minutes might be the best solution. I don't think shutting it off in gear is a great idea. I will try the octane booster though. Thanks again.
