1216bandit
- Joined
- Aug 18, 2008
- 214
Engine serial 0F075410. Every once in a while the engine will diesel a bit when shut off and from the reading I have been doing it seems like it could be something as simple as too high an idle speed. I'm just a little confused about the proper way to check and make any adjustment. Some of what I've read says neutral on the trailer is fine, others say check or adjust in the water at idle in gear, some also mention disconnecting the throttle at the carb while at idle in gear. Can I do this while the boat is on the trailer?? I will be using a friends timing light with tach to check rpm's.
Thanx! Dan
Thanx! Dan
