Re: 4.3 To 5.7 Swap
Lets use an example. If I have a engine (or gerbal) that can produce 200 lbft of torque at 2000 RPMs I would use one set of gears. If I had an engine (or a bigger gerbal) that can produce 300 lbft at 2000 RPMs I would use a different set of gears to spin th prop faster.
In this posters case, if he ups the output of the existing 4.3 liter (deliver more torque) he would need to change gearing just as if he installed a monster big block. Its ALL about the torque...
Ayuh,... I Agree,.. I think...
While what you're saying about it being All about Torque,.. I totally Agree with....
And,..
While your summarizations of the of the need to Regear, whether it's a slightly Hopped Up 4.3l, or a BBC, is in the least somewhat misleading,...
In that some Regearing is most always done with the Prop....
The Idea, of gearing in our outdrives is to absorb
All of the available Torque from our Motors, at the most reasonably,+ applicable RPMs....
Props are only normally available in the 15" to maybe 23" or 25" Tops range....
Too much Torque from the motor,+ you need taller gears in the drive....
'cause you Can't buy a prop Big enough...
Not enough Torque from the motor,+ it'll Never make any RPMs,+ No Torque, or Horsepower,....
Probably Grenading from detonation...
'cause you Can't buy a prop Small enough....
The Whole Idea is to Stall the motor at it's RPM where it's making it's Greatest Torque.....
That's where the motor is gving
All there is to give,+ just Can't produce anymore Torque to raise the RPMs,+ Horsepower.....
