4,3 Volvo Penta Riser Extension = PURPOSE
alan ber
I have twin 4.3 Volvo Penta engines on my Regal
Needed too get too Kohler Gen ,
Difficult too reach areas of gen set since its tucked under deck and riser of port engine stops my arm from reaching
Removed riser & external oil filter , ,
Have supply of green Volvo Penta gaskets ( from previous owner ) ,
Riser & manifold was changed 10 months ago , ( new long blocks , shop used Sierra )
Boat used in salt water , ,
10 months , 75 hours since new long blocks , CRUD in water passage ? , Flush engines after each use ,
Next agenda is too removed other risers & making sure they are clean
QUESTION
Purpose of 3 inch extensions or any extension under riser , NECESSARY ?
Original design a table top is stored under deck ,. Since new manifolds / risers top hits risers and deck
lid can not close flush
thanks as usual
QUESTION
If risers were added, they are necessary. That means your boat is heavy, and sitting low, and the elbow to static water line measurement was less that 14"
If you remove the risers, most likely you will end up hydro-locked because water will fill your engine thru the exhaust.
alan ber
Scott
I was thinking prior too my post , Has too be a reason why a 3 inch extension is use
On my Volvo , manifold , then 3 inch extension , then riser gets bolted too extension
Was curious , looks like riser would connect directly too manifold , Purpose of Extension adds more height would stop
back flow ? . higher over engine ,
I had no plans on changing just curious why the use of an extension
Ayuh,..... As Scott said, the bottom of the exhaust cavity, inside the riser, HAS to be 13.5" or higher, than the waterline, outside the hull,.....
Lubak572
So along that line would it be beneficial to run taller ones when replacing if clearance isn't an issue. Would it hurt cooling or performance?
Ayuh,..... Either you have the height, or ya don't,.....
Addin' extensions ya don't need just adds weight, 'n expense,....
