4.3 vortec head torque sequence?
Lou C
You really need a shop manual. There are different torque specs depending on what version of the 4.3 you have. The old models use 65 ft lbs and you go in 3 sequences bring it gradually up to full torque (like torque all the bolts in the pattern 20 ft lbs, 40 ft lbs then 65 ft lbs). The newer ones, use a totally different procedure.
