utexasrick
- Joined
- Apr 25, 2011
- 46
I have a 4.3 2 barrel which I recently installed but I can not keep the engine running. It will start up the first time and will idle for maybe 40s then it dies. I can start it up again but it will do the same. I thought it was dying when the chock was opening so I held it slightly open but it still died. I took the boat out to the lake and it would shift fine and accelerate but it did the same thing after a few seconds it would die. At one point it was accelerating and it died midway.
Could this be an issue with bad gas. half was old gas that had been sitting for a few months, I had added fuel stabilizer when I got the boat and a couple gallons of 93 the last time I tried to take it out. I would think if it was bad gas it would be very hard to start.
I also replaced the fuel filter/separator and checked the fuel filer behind the fuel inlet in the carb, it was clean.
Anyone one have any ideas on what I could check next
How could I check to see if I'm losing spark when its dying?
