whitebunnyflock
- Joined
- Jul 12, 2017
- 64
There is no way that this won't be a long story so here it is.
This is a Volvo Penta 4.3GL PBYC serial number 4110167965. Since I have had it since spring 2017 it has only been run in fresh water. This is a 1999 model boat. I doubt the previous owner had run it in salt water but you never know.....
I should also note that since I have had the boat it has never reached operating temperature. I put the temperature sensor sender lead to ground and it makes the temperature gauge reach max (so i assume the gauge itself is working). I replaced the sensor itself in the last couple years because i thought maybe it was a faulty sensor. I should also note that I put aviation gasket on the threads of the sensor which I am not sure was the greatest idea. I also replaced the thermostat around this time.
Years ago i had posted that the starboard exhaust riser had overheated and the rubber attached to it to vent the exhaust had heated to the point where it started to smoke. At that time I had taken it to a boat shop and they had put a new impeller in it. So I thought... problem solved. This was in 2017. Spring 2019 I had replaced the impeller again even though it appeared to not need it.
Last weekend I took it out and ran at WOT and not long (maybe 5 minutes) and a bunch of smoke coming off the same exhaust riser lower rubber part (sorry not sure what it is called). This had not happened since 2017 although i have always noted that the starboard exhaust riser is significantly hotter than the port riser. I could keep my hand on the port exhaust riser all day and i can't keep my hands on the starboard exhaust riser for more than a few seconds.
Yesterday I pulled the hose off the t-stat housing as i wanted to run some water through with the garden hose to see if there is a blockage on the starboard exhaust riser. I did note some rust on the port on the t-stat housing, not sure if this could be reducing water flow to that exhaust riser. Some flecks may have come out but hard to say as they appeared as the flecks that came off the rubber exhaust venting but the water came through the drain plug i pulled off and it appeared to flow steady and clear (so i don't think there is a blockage there, but i am no pro at this).
We took the boat out again after i checked this and we ran for a few minutes at WOT and even though the starboard exhaust riser was extremely hot there was no smoke. We ran for a bit at 20-35 miles an hour (top speed on this thing is 44 miles an hour). Again as far as I could tell the engine did not even reach 100 degrees fahrenheit (this is how it has always been since I got the boat with and without the new temp sensor and thermostat).
Steps to fix (i haven't done this yet)
I was thinking about the following steps to see what else I could determine. i am not 100% sure that the temperature sensor (even though it is new) is doing what it should. I was thinking about cleaning the permatex aviation gasket stuff off it as I am not certain good contact is being made (although should it really matter?). I was also thinking about doing the thermostat hot water boil test to see if it is actually operating properly. I would also strongly consider replacing the t-stat housing completely as it is 21 years old and it would be nice to just start fresh (perhaps it would take another 10 or 15 years to get rusty then).
I have also had the exhaust risers off completely in the past and noted some corrosion but I didn't think it would be enough to impact the performance (I put new gaskets in at the time).
I would guess that my t-stat is remaining wide open or else one would think it would reach proper operating temp? Pretty sure I put in a 140 degree t-stat when i replaced it (i did buy it at the boat shop).
Also can I safely assume that the corrosion in the housing is what is leading to my starboard exhaust riser getting so much hotter than the port side?
