Hi gang, I could really use some help here, thanks in advance.
2001 Glastron 185GX 4.3GL Volvo Penta Engine. I have a crank, no start condition. I did recently replace the starter. I've determined that the carb is not getting fuel when cranking from the fuel pump when the cranking. If I pour gas in the carb it will run for 1-2 seconds, then die. With the fuel line disconnected at the carb nothing comes out, but it does come out if I put 12v direct.
As far as further diagnostics here's what I've determined/done:
- Put 12v to fuel pump directly from battery, and determined it runs and pumps gas steadily to carb line (from both tank or seperate gas can) Which should in theory eliminate anti-siphon valve and confirms that the fuel pump at least works moderately well.
- Tested relay by putting 12v and ground to 85 + 86 and I get a click. Not sure if this is really a conclusive test to the internals of the relay, so I think I should replace it anyway.
- Confirmed I get 12v on terminal 30 of the fuel pump relay wire harness.
- Confirmed I get 12v at the fuel pump wire connector downstream of the relay when I am cranking the ignition.
- Confirmed continuity of the ground wire at the fuel pump relay wire harness.
- I tested the diodes both the alternator to fuel pump circuit (green) and starter to fuel pump harness (red/yellow) wire. I got ~500mA going one way and OL going the other way, which I believe means both diodes and connections are okay, but I don't mess with diodes ever.
- I tried using a single jumper wire from terminal 87 (fuel pump wire) to terminal 30 (always on 12v wire), nothing happened which was interesting because I thought that would turn on the fuel pump. I'd like to try this again to make sure I'm not going crazy, unless I am missing something. The terminal had continuity to the fuel pump connector end, both the ground wire on the fuel pump connector and the fuel pump harness show continuity to battery ground as well.
- Fuel pump 7.5amp fuse is good and I've also swapped spare fuse(s) with no luck. 40 amp fuse is good as well.
