Re: 4.3l automotive in a boat??
You need to get the boat OUT of the water, then remove the outdrive, THEN you remove the engine and put the new one back in. Then yo align the engine with an alignment bar, and only then do you reinstall the drive.
What you suggest is going to turn into an expensive hobby of pulling the engine and replacing couplers because the engine isn't aligned properly.
Yes, some things on boats requier special equipment and knowledge.
I'm gona go ahead and put up my hand here.
Yeah, I did that, I did exactly that. And now have have a new coupler, and I know how to replace a gimbal bearing and align a motor. =)
On a side note:
I welded both my cracked manifolds with my mig welder and they've worked perfectly for 2 seaons.
Each had about an 8" crack, and an offset, I used a hammer to bend the offset back, I used my angler grinder and made a big V in the crack, then I used my mig welder and filled in the V, they've worked perfectly thus far, not a single leak, Oh yeah and I painted them with POR 15
I'm using a 2001 chev astro motor in my boat, and with a new prop, I went from 50 or so MPH to 63 on the GPS.
Going from the old odd-fire, old scholl heads, 2 barral carbed setup to the even fire, vortec, EFI setup made a HUGE difference in power and fuel economy.
In terms of going from an automotive mechanic to a marine one, you've done the right thing, you came here first.
The drive's are pretty simple, get yourself a manual and just make sure you read before you do.
Removing the engine:
1. Remove the drive (usually 6 bolts, pretty simple, remember always use new gaskets when reassembling)
2. Undo the side and rear engine mounts.
3. The obvious (fuel, electrical, cooling)
4. use a shop crane and pull the engine.
Installing the engine is the reverse except:
Before you reinstall the drive, you use an alignment tool and align the engine. Do it carefully, if you don't, you will strip your coupler splines like I did.
