EBBTIDE182
- Joined
- Jun 20, 2011
- 31
Hey guys i have recently gotten a new boat from my dad. Its a 92 ebbtide 182 with a 4.3l mercruiser lx thunder bolt ignition i believe is what it says on the carb cover. My dad bought this boat right around 3 years ago we had some problems with the boat not wanting to start very easy even after it was warmed up. Wasnt a big issue we took it to the authorised merc dealer in spring field which was bass pro and they rebuilt the carb on it and tuned it and as of now the boat runs great starts right up. The boat on top end will run 45 at 4700 rpm with a 21 pitch prop. Any ways last year over labor day my parents were at the lake and forgot to put the plug in the boat which in return poured water into the back almost sinking the boat. Water was just below the spark plugs but the boat stayed running the whole entire time and they quickly got it back to the boat ramp and got it out of the water and got all the water out of it put a new plug in it and used it all weekend. After it was winterized and sat all winter my dad and i traded my tractor for his boat, because i would get more use out of the boat then the tractor. any ways this spring i got it out and the starter was dragging really bad on it which i figured being it was under water and a 92 model. not a big deal had it rebuilt and put it back on and the boat fired right up and sounded good. roughly about a month later this being yesterday (6-19) we decided on a wild hair to go to the local lake. After putting the boat in the water we set out on the lake and it sounded like tree limbs draging along the bottom of the boat (which mind you there werent just my description of what it sounded like) and my power steering was a little stiff. So i headed back to the dock and tied back up and started checking things but i still have not figured out what this noise is. We went ahead and ran the boat and it ran great and when sitting at the dock and i would get my rpms up the noise would go away but at idle and just above like 1500 or enough speed to tighten the rope up on a skier the noise was just horriable. I checked all of oils power steering fluid engine oil trim oil and every thing checked good. Now i am suspecting power steering problems just because it was stiff while using it. At first i thgouth maybe a water pump issue maybe in the engine or the outdrive but the boat never got about 150 deg. so i have ruled that out. Some one said a rusted timing chain from when it was under water but i dont think the water got in to it to do any of that. Plus there was not a drop of water in the engine oil when i changed it this spring. My description of the noise could be a little better but thats what it kind of sounded like to me. But would any one maybe have an idea of what possiably might of happened to make this noise?
